SketchBook Forum
Hello Sketchbook Community Members! Sketchbook started a new exciting endeavor. This forum is now read-only mode. Please visit the new Sketchbook Help Center, https://help.sketchbook.com/ in the future. Happy sketching!
won't log in
18 REPLIES 18
Message 1 of 19
1671 Views, 18 Replies
won't log in
Trial verson as of today on windows 7 (64bit)
I get "Something is wrong with the internet connection" and it won't log-in.
However, I'm posting here, and it updates fine, so I have i-net connection.
Thoughts?
Anyone know what port it uses, in case I have it blocked (or Kaspersky/Malware Bytes is) and I can add an exception?
thank you
18 REPLIES 18
Message 2 of 19
bogdan.oancea
I would:
  • Run a Windows Update
  • Reboot the computer.
  • Try to login to SketchBook again from 'My Acounts' menu > Sign In.
Message 3 of 19
in reply to: bogdan.oancea
Thanks BogDan, but no luck.  Somehow the app is not getting out to login, but updates without issue.
Message 4 of 19
vfongwm
Hi haleyCUKJ7,
Can you download and re-install the app and try to login again? If you still can't login - could you send a screenshot of the error msg + Windows OS version and device type?
Vivian
Message 5 of 19
in reply to: vfongwm
Had time to get back to this . . .
I uninstalled and re-installed, still no luck.  Upon starting it displays a "something is wrong with your internet connection" and I am unable to login.  However, it updates fine.
The only thing atypical with the install is it's on the 😧 drive while windows is on C:
Windows 7 Professional  ver 6.1.7601
Device PC home built, but never had software issues.  My guess a firewall or antivirus is blocking a port that Sketchbook uses.  If I could get the port numbers I could make an exception for sketchup on that port.
Thanks.
Message 6 of 19
david.lau
@Anonymous I have send you a PM.
David Lau
Message 7 of 19
in reply to: david.lau
@david.lau same problem here, I tried all the above
Message 8 of 19
I have the same problem. I assume I need you to PM me too? I am unable to use sketchbook on my PC. Waiting....
Message 9 of 19
I have the same issue.  Cannot log on to to upgrade. I purchased the upgrade and it is not letting me use it.  Can someone help?
Message 10 of 19
david.lau
@Anonymous,  @Anonymous  I  have send a PM to the both of you....
David Lau
Message 11 of 19
David Lau,
Would you PM me too?  Thanks.
Message 12 of 19
Send me a PM too?
Message 13 of 19
same problem.
and this "david lau" keeps sending pms to this very problem. i smell something fishy.
i bet is something related to "switch to windows 10" because u all know we reverted to windows 7 to escape the useless bloatware that is windows10.
Message 14 of 19
Bm2m
Hi.
Can you send me a PM please?
Message 15 of 19
I'm having the same issue. Is there still a working solution?
Thank you!
Message 16 of 19
I have the same issue but it only happens when I'm away from Wi-Fi on my surface. When I'm at home it logs in just fine but away from Wi-Fi I get the login screen with no x to close like on my wife's computer. When you try and hit login it comes up with the "something wrong" message, obviously with no internet, but this means i cant use the app away from WiFi at all.
Message 17 of 19
david.lau
@Anonymous, @Anonymous, @Bm2m
Please log a ticket with us via:
https://forums.autodesk.com/t5/sketchbook-forum/won-t-log-in/m-p/8107274
Depending on the OS, product version, the solution is different....
David Lau
Message 18 of 19
Mesmo problema aqui. Não consigo atualizar nem baixar recursos extra.
Technology Administrators
