Error occurred with module: mknso.exe-Transient Stress (Modal Superposition)
How to solve this problem?
Autodesk (R) Simulation ,636,102,212,147(,169,577,472,152)
Version 2017.00.00.3131-W64/X64 10-Mar-2016
Copyright (c) 2016, Autodesk, Inc. All rights reserved.
PROGRAM VERSION: 201700003131
alg-win-x64.dll VERSION: 201700003131
algconfig-win-x64.dll VERSION: 201701003176
agsdb_ar-win-x64.dll VERSION: 201700003131
solvercallback-win-x64.dll VERSION: 201700003131
amgsolve.exe VERSION: 0360000000
**** Model Unit System Settings:
Unit System : !,258,450,041
Force : N
Length : mm
Time : s
Temperature (Absolute) : deg C (K)
Thermal Energy : J
Voltage : V
Current : A
Electrical Resistance : ,431,982
Mass : N*s^2/mm
DATE: AUGUST 9, 2021
TIME: 11:57 AM
INPUT MODEL: ds
MODAL ANALYSIS FILE....F:\Vault-,037,316,991,214,841\Design\,740,457',033,446\2021\,216,415',044,740\XB2021-01-00+,160,577,204 ,467,500,160,577,305,615,740,350\02#,774#,745,968,454\,223,495,998,512\,333,482HM11,256,863,120,223,495,998,512\XB2021-01-00+zhp+P1102312-07-100kg.ds_data\6\ds
1**** CONTROL INFORMATION
number of node points (NUMNP) = 57541
number of element types (NELTYP) = 4
number of load cases (LL) = 2000
number of frequencies (NF) = 0
analysis type code (NDYN) = -2
equations per block (KEQB) = 0
**** Checking modal file node consistency
**** EQUATION PARAMETERS
total number of equations = 172833
bandwidth = 1
number of equations in a block = 5762
number of blocks = 30
**** Hard disk file size information for processor:
Available hard disk space = 539318.996 megabytes
1**** TIME HISTORY ANALYSIS (MODE SUPERPOSITION)
**** TIME HISTORY CONTROL INFORMATION
number of time functions (NFN) = 1
ground motion indicator (NGM) = 1
number of arrival times (NAT) = 5
number of time steps (NT) = 2000
output print interval (NOT) = 1
time step (DT) = 1.5400E-05
damping factor (DAMP) = 5.0000E-02
1**** DYNAMIC NODAL FORCES/MOMENTS
NODAL TIME ARRIVAL FUNCTION
NODE D-O-F FUNCTION TIME SCALE
NUMBER INDEX NO. NO. FACTOR
2 2 1 5 9.800E+02
1**** GROUND ACCELERATION INPUT
X-DIR Y-DIR Z-DIR
TIME FUNCTION NUMBER(S) = 0 0 0
ARRIVAL TIME NUMBERS(S) = 1 1 1
Warning nodal loads with ground motion Untested
1**** ARRIVAL TIME DEFINITIONS
NUMBER ARRIVAL TIME
1 0.0000E+00
2 0.0000E+00
3 0.0000E+00
4 0.0000E+00
5 0.0000E+00
1**** PRINT OF NATURAL FREQUENCIES
mode circular
number frequency frequency period
(rad/sec) (Hertz) (sec)
1 2.1744E+03 3.4606E+02 2.8897E-03
2 3.8838E+03 6.1812E+02 1.6178E-03
3 8.2722E+03 1.3166E+03 7.5955E-04
4 1.1636E+04 1.8519E+03 5.3999E-04
5 1.4893E+04 2.3704E+03 4.2188E-04
6 1.8474E+04 2.9402E+03 3.4011E-04
7 2.3237E+04 3.6982E+03 2.7040E-04
8 2.9484E+04 4.6925E+03 2.1311E-04
9 3.6336E+04 5.7830E+03 1.7292E-04
10 5.3063E+04 8.4453E+03 1.1841E-04
11 5.8267E+04 9.2734E+03 1.0784E-04
12 5.9955E+04 9.5421E+03 1.0480E-04
13 9.6262E+04 1.5321E+04 6.5272E-05
14 1.0718E+05 1.7058E+04 5.8624E-05
15 1.2508E+05 1.9907E+04 5.0234E-05
1**** TIME FUNCTION DEFINITIONS
time function number = 1
number of abscissae = 4
function scale factor = 1.0000E+00
FUNCTION DESCRIPTION: Load Curve 1
TIME AMPLITUDE
1 0.0000E+00 0.0000E+00
2 6.1600E-05 0.0000E+00
3 1.5400E-04 1.0000E+00
4 1.5400E-02 1.0000E+00
1**** OUTPUT: DISPLACEMENT COMPONENT REQUESTS
NODE NODAL D-O-F CODES
NUMBER * * * * * *
**** Preparing to write displacement output file
Maximum absolute values of displacement from output time steps
X transl. Y transl. Z transl. X rot(deg) Y rot(deg) Z rot(deg)
Node no. 245 1310 2936 3972 3974 434
Maximum 5.747E-02 7.233E-01 -8.226E-02 -1.589E-01 1.558E-02 -1.640E-01
Time 4.928E-04 9.394E-04 9.240E-04 9.240E-04 8.008E-04 4.774E-04
1**** TEMPORARY FILE STORAGE (MEGABYTES)
UNIT NO. 7 : 19.783
UNIT NO. 8 : 2.634
UNIT NO. 9 : 1.319
UNIT NO. 10 : 0.000
UNIT NO. 11 : 0.000
UNIT NO. 12 : 0.000
UNIT NO. 13 : 0.000
UNIT NO. 14 : 0.000
UNIT NO. 15 : 0.000
UNIT NO. 17 : 0.000
TOTAL : 23.736
1**** END OF FILE
