Error occurred with module: mknso.exe-Transient Stress (Modal Superposition)
lihouxin065
lihouxin065
How to solve this problem?
Autodesk (R) Simulation ,636,102,212,147(,169,577,472,152)
Version 2017.00.00.3131-W64/X64 10-Mar-2016
Copyright (c) 2016, Autodesk, Inc. All rights reserved.
PROGRAM VERSION: 201700003131
alg-win-x64.dll VERSION: 201700003131
algconfig-win-x64.dll VERSION: 201701003176
agsdb_ar-win-x64.dll VERSION: 201700003131
solvercallback-win-x64.dll VERSION: 201700003131
amgsolve.exe VERSION: 0360000000
**** Model Unit System Settings:
Unit System : !,258,450,041
Force : N
Length : mm
Time : s
Temperature (Absolute) : deg C (K)
Thermal Energy : J
Voltage : V
Current : A
Electrical Resistance : ,431,982
Mass : N*s^2/mm
DATE: AUGUST 9, 2021
TIME: 11:57 AM
INPUT MODEL: ds
MODAL ANALYSIS FILE....F:\Vault-,037,316,991,214,841\Design\,740,457',033,446\2021\,216,415',044,740\XB2021-01-00+,160,577,204 ,467,500,160,577,305,615,740,350\02#,774#,745,968,454\,223,495,998,512\,333,482HM11,256,863,120,223,495,998,512\XB2021-01-00+zhp+P1102312-07-100kg.ds_data\6\ds
1**** CONTROL INFORMATION
number of node points (NUMNP) = 57541
number of element types (NELTYP) = 4
number of load cases (LL) = 2000
number of frequencies (NF) = 0
analysis type code (NDYN) = -2
equations per block (KEQB) = 0
**** Checking modal file node consistency
**** EQUATION PARAMETERS
total number of equations = 172833
bandwidth = 1
number of equations in a block = 5762
number of blocks = 30
**** Hard disk file size information for processor:
Available hard disk space = 539318.996 megabytes
1**** TIME HISTORY ANALYSIS (MODE SUPERPOSITION)
**** TIME HISTORY CONTROL INFORMATION
number of time functions (NFN) = 1
ground motion indicator (NGM) = 1
number of arrival times (NAT) = 5
number of time steps (NT) = 2000
output print interval (NOT) = 1
time step (DT) = 1.5400E-05
damping factor (DAMP) = 5.0000E-02
1**** DYNAMIC NODAL FORCES/MOMENTS
NODAL TIME ARRIVAL FUNCTION
NODE D-O-F FUNCTION TIME SCALE
NUMBER INDEX NO. NO. FACTOR
2 2 1 5 9.800E+02
1**** GROUND ACCELERATION INPUT
X-DIR Y-DIR Z-DIR
TIME FUNCTION NUMBER(S) = 0 0 0
ARRIVAL TIME NUMBERS(S) = 1 1 1
Warning nodal loads with ground motion Untested
1**** ARRIVAL TIME DEFINITIONS
NUMBER ARRIVAL TIME
1 0.0000E+00
2 0.0000E+00
3 0.0000E+00
4 0.0000E+00
5 0.0000E+00
1**** PRINT OF NATURAL FREQUENCIES
mode circular
number frequency frequency period
(rad/sec) (Hertz) (sec)
1 2.1744E+03 3.4606E+02 2.8897E-03
2 3.8838E+03 6.1812E+02 1.6178E-03
3 8.2722E+03 1.3166E+03 7.5955E-04
4 1.1636E+04 1.8519E+03 5.3999E-04
5 1.4893E+04 2.3704E+03 4.2188E-04
6 1.8474E+04 2.9402E+03 3.4011E-04
7 2.3237E+04 3.6982E+03 2.7040E-04
8 2.9484E+04 4.6925E+03 2.1311E-04
9 3.6336E+04 5.7830E+03 1.7292E-04
10 5.3063E+04 8.4453E+03 1.1841E-04
11 5.8267E+04 9.2734E+03 1.0784E-04
12 5.9955E+04 9.5421E+03 1.0480E-04
13 9.6262E+04 1.5321E+04 6.5272E-05
14 1.0718E+05 1.7058E+04 5.8624E-05
15 1.2508E+05 1.9907E+04 5.0234E-05
1**** TIME FUNCTION DEFINITIONS
time function number = 1
number of abscissae = 4
function scale factor = 1.0000E+00
FUNCTION DESCRIPTION: Load Curve 1
TIME AMPLITUDE
1 0.0000E+00 0.0000E+00
2 6.1600E-05 0.0000E+00
3 1.5400E-04 1.0000E+00
4 1.5400E-02 1.0000E+00
1**** OUTPUT: DISPLACEMENT COMPONENT REQUESTS
NODE NODAL D-O-F CODES
NUMBER * * * * * *
**** Preparing to write displacement output file
Maximum absolute values of displacement from output time steps
X transl. Y transl. Z transl. X rot(deg) Y rot(deg) Z rot(deg)
Node no. 245 1310 2936 3972 3974 434
Maximum 5.747E-02 7.233E-01 -8.226E-02 -1.589E-01 1.558E-02 -1.640E-01
Time 4.928E-04 9.394E-04 9.240E-04 9.240E-04 8.008E-04 4.774E-04
1**** TEMPORARY FILE STORAGE (MEGABYTES)
UNIT NO. 7 : 19.783
UNIT NO. 8 : 2.634
UNIT NO. 9 : 1.319
UNIT NO. 10 : 0.000
UNIT NO. 11 : 0.000
UNIT NO. 12 : 0.000
UNIT NO. 13 : 0.000
UNIT NO. 14 : 0.000
UNIT NO. 15 : 0.000
UNIT NO. 17 : 0.000
TOTAL : 23.736
1**** END OF FILE
John_Holtz
Autodesk Support
Autodesk Support
Hi @lihouxin065
It is difficult to know what causes the problem from the log file.
  • What type of load is applied? (The file implies that you have both a ground motion and a force. You should only apply one or the other, not both.)
  • When does the error occur? Soon after the analysis starts? At the end of the analysis?
  • Are you outputting all 2000 time steps? That would result in files that are over 2 GB in size. (I am not sure if Sim Mech Transient Stress supports files over 2 GB or not.) When the analysis ends, are any of the files in the DS folder over 2 GB in size?
If you do not find the solution, someone can take a look at the model if you make an archive ("app button > Archive > Create > Model Only") and attach the archive file (.ach) to the forum post.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
lihouxin065
@John_Holtz
(1)There is  node displacement results,but no strain/stress results like(No-Stress-results-on-DDAM-with-a-high-number-of-modes-in-Simulation-Mechanical ),
(2)I run mknso.exe  from  DOS Window follow the directions onHow-to-run-a-Simulation-Mechanical-analysis-from-the-command-prompt-DOS-window ).
(3)then I get a forrt1:sever(170): progam exception-stack overflow, the mode maybe too lage(General Fortran Error Messages )
lihouxin065
@John_Holtz the Design Scenario file is about 5 GB.
