NO strain result in Frequency Response Analyses
lihouxin065
lihouxin065
result no strain tensorresult no strain tensoroutput settingoutput settingelement settingelement setting
lihouxin065
Could  somebody give me a favor 🤔
lihouxin065
The help file tells me there's no strain amplitude result  in Frequency Response Analyses!(File Extension Summary )
so ,if  I need the strain amplitude -Frequency curve ,what should I do ?2.pngthe strain amplitude -Frequency curve ,what should I do ?
John_Holtz
Autodesk Support
Autodesk Support
Hi @lihouxin065
Good catch to find that the documentation indicates there is no strain output.
You will need to use some theory to calculate the strain manually. Stress/strain = modulus of elasticity is too simple for a 3D stress state, but that equation would get you close. What you want are the equations to convert the 6 stress tensors (Sxx, Syy, ... Szx) to the 6 strain tensors.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
lihouxin065
Yes. Thank you John! Generalized Hooke's Law can be used。
