- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
result no strain tensor
output setting
element setting
output setting
element setting
Could somebody give me a favor 🤔
The help file tells me there's no strain amplitude result in Frequency Response Analyses!(File Extension Summary )
so ,if I need the strain amplitude -Frequency curve ,what should I do ?the strain amplitude -Frequency curve ,what should I do ?
Hi @lihouxin065
Good catch to find that the documentation indicates there is no strain output.
You will need to use some theory to calculate the strain manually. Stress/strain = modulus of elasticity is too simple for a 3D stress state, but that equation would get you close. What you want are the equations to convert the 6 stress tensors (Sxx, Syy, ... Szx) to the 6 strain tensors.
Yes. Thank you John! Generalized Hooke's Law can be used。
