VBA Excel macro for any object geometry modifications (API)
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
For those who might be interested I am attaching xls file with macro for objects geometry modifications.
One button to import geometry (characteriscic points coordinates) of selected objects (lines, polylines, arc, circles, panels), second - to update their geometry basing on data in Excell.
NOTE: modify only cells with coordinates.
Rafal Gaweda
Replies (63)
Message 21 of 64
Is it possible to export through this add-in the thickness as well?
Message 22 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Sure.
Attached.
Rafal Gaweda
Message 23 of 64
Thank Rafal!
But I didn't understand in which cell I can change the thickness!
Message 24 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Column C if you are using objects_geometry_with_rounding_5.xlsm
Rafal Gaweda
Message 25 of 64
OK, but what if...I want to have my own thickness and instead of creating it in a software I put it in an excel. Is it possible to load that thickness(defined in an excel sheet) to the software whether I always must create corresponding one in the software?
Message 26 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Sure it is.
You have to add \ write such code.
Rafal Gaweda
Message 27 of 64
Could do you it for me, please? I'm no able to write a code.
Message 28 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Have fun.
Attached
Rafal Gaweda
Message 29 of 64
Hi @Rafal.Gaweda is it possible to get dimensions from a bar? I 'm missing that code!
Can you help me please?
Thank you so much!
Message 30 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
My understanding is : Bar dimension = bar length
Bar length is calculated as distance between bar start node and endnode.
If you want to change bar length you have to move node(s).
See this addin.
Rafal Gaweda
Message 31 of 64
My bad @Rafal.Gaweda, for dimensions I mean B (base) and H (height) of the concrete section
Message 32 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Do you mean RC cross section dimensions?
Example here.
Rafal Gaweda
Message 33 of 64
@Rafal.Gaweda Importing into excel both dimensions B and H from a RC section in Robot
Message 34 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Look at the example I pointed you.
Instead of ...SetValue use ...GetValue
Rafal Gaweda
Message 35 of 64
What a long-standing forum! The add-in has clearly withstood the test of time...
Anyways, you can see in the screenshot that only 5 of hte nodes updated. This is because I added two intermediate points in the definition of hte panel, and I suspect the add-in doesn't support the addition of points -- it will only update the existing points.
Can you confirm I understand that correctly, or if there is in fact a way to add intermediate points to the definition of a panel with this add-in?
Message 36 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Exactly.
Rafal Gaweda
Message 37 of 64
Thanks Rafal. IF I was better at programming, I'd add that feature. I was easily able to copy the coordinates in the Excel table, into the Robot coordinates table for the definition of this panel -- so it wasn't hopeless.
Message 38 of 64
Hi @Rafal.Gaweda I did:
Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_SECTION, LabelName)
Set RBSD = RLabel.Data
    RBSD.ShapeType = I_BSST_CONCR_BEAM
    Set RBSCRD = RBSD.Concrete
    RBSCRD.GetValue I_BSCDV_BEAM_B, (Cells(Row, 10).Value)
but i get the following error:
"Wrong number of arguments or invalid property assignment"
Message 39 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
My understanding is you want to GET it so example below:
Dim RLabel As RobotLabel
Dim RBSD As RobotBarSectionData
Dim RBSCRD As RobotBarSectionConcreteData
Set RLabel = RobApp.Project.Structure.Labels.Get(I_LT_BAR_SECTION, "B 30x50")
Cells(1, 10) = RBSCRD.GetValue(I_BSCDV_BEAM_B)
Rafal Gaweda
Message 40 of 64
My bad @Rafal.Gaweda, what I mean is to get for a generic beam both base and height dimensions from robot into excel.
In your example I think is for a specific beam "B 30x50"
