VBA Excel macro for any object geometry modifications (API)
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
For those who might be interested I am attaching xls file with macro for objects geometry modifications.
One button to import geometry (characteriscic points coordinates) of selected objects (lines, polylines, arc, circles, panels), second - to update their geometry basing on data in Excell.
NOTE: modify only cells with coordinates.
Rafal Gaweda
Replies (63)
Message 41 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
What do you mean by "generic"?
This was example for concrete beam section.
Cells(2, 10) = RBSCRD.GetValue(I_BSCDV_BEAM_H)
Rafal Gaweda
Message 42 of 64
@Rafal.Gaweda Concrete beam section is generic for me!!!Smiley LOL
But still does not work something...
Dim RLabel As RobotLabel
Dim RBSD As RobotBarSectionData
Dim RBSCRD As RobotBarSectionConcreteData
Dim LabelName As String
Set RBSD = RLabel.Data
Set RBSCRD = RBSD.Concrete
Cells(10, 10) = RBSCRD.GetValue(I_BSCDV_BEAM_B)
Cells(11, 10) = RBSCRD.GetValue(I_BSCDV_BEAM_H)
Message 43 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Rafal Gaweda
Message 44 of 64
why do I get always a beam 30 x 50? Also I do not understand why this row:
Set RLabel = RobApp.Project.Structure.Labels.Get(I_LT_BAR_SECTION, "B 30x50")
the bar section can have whatever dimensions.
Message 45 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
This was JUST EXAMPLE.
Replace "B ...." by labelname \ string.
Rafal Gaweda
Message 46 of 64
@Rafal.Gaweda I have tried but...still problem Man Frustrated
Set RLabel = RobApp.Project.Structure.Labels.Get(I_LT_BAR_SECTION, "Labelname")
Set Labelname = String
Message 47 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
@Anonymous
Dim Labelname as String
Labelname = "B 30x50" ' here you have to give \ input real section name
Set RLabel = RobApp.Project.Structure.Labels.Get(I_LT_BAR_SECTION, Labelname)
Rafal Gaweda
Message 48 of 64
Thanks @Rafal.Gaweda for you patience!
What I do not understand if it is mandatory to write a Labelname (e.g. "B 30x50") or is it possible to skip it. Because like this I need to know, before importing dimensions into excel, the labelname of the section. I cannot import dimensions without know the labelname, nevertheless each time I have to change LabelName in the code.
For example, if you want to get thickness  value for panels, you do not need to know the panel's thickness name.
the code is:
 Set THData = Obj.GetLabel(I_LT_PANEL_THICKNESS).Data
                If (THData.ThicknessType = I_TT_HOMOGENEOUS) Then
                        Set HomoThickData = THData.Data
                        If (HomoThickData.Type = I_THT_CONSTANT) Then
                        Cells(Row, 2) = HomoThickData.ThickConst
Now, is it a code where I can get bar section dimensions directly as we do for panel?
Message 49 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Sure you can do it in similar way.
Example code :
Dim Bar As RobotBar
Dim SectionLabel As RobotLabel
Set Bar = RobApp.Project.Structure.Bars.Get(1)
Set SectionLabel = Bar.GetLabel(I_LT_BAR_SECTION)
Set RBSD = SectionLabel.Data
If (RBSD.ShapeType = I_BSST_CONCR_BEAM_RECT) Then
    Cells(1, 1) = RBSCRD.GetValue(I_BSCDV_BEAM_B)
    Cells(2, 1) = RBSCRD.GetValue(I_BSCDV_BEAM_H)
Rafal Gaweda
Message 50 of 64
But...I get this error
Message 51 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Do you have bar number 1 in your model?
The example code works for bar with number 1.
Rafal Gaweda
Message 52 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
@Anonymous
Do you have such line in your code:
Dim Bar As RobotBar
 or
Dim Bar As IRobotBar
Rafal Gaweda
Message 53 of 64
@Rafal.Gaweda
Can It works for any bar?
Because If i do not put any bars number between brackets I do not get value
Set Bar = RobApp.Project.Structure.Bars.Get()
Message 54 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
If "any" means every RC Beam with rectangular section :
Dim Bar As RobotBar
Dim BarCollection As RobotBarCollection
Set BarCollection = RobApp.Project.Structure.Bars.GetAll
Row = 1
For I = 1 To BarCollection.Count
Set Bar = BarCollection.Get(I)
    Cells(Row, 1) = RBSCRD.GetValue(I_BSCDV_BEAM_B)
    Cells(Row, 2) = RBSCRD.GetValue(I_BSCDV_BEAM_H)
    Row = Row + 1
Next I
Rafal Gaweda
Message 55 of 64
Thank so much @Rafal.Gaweda,
if you could do the last effort would be great!
Is it possible to import only bars that are selected in Robot, instead of importing all of them please?
Message 56 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Have fun:
Dim BarSelection As RobotSelection
Set BarSelection = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Set BarCollection = RobApp.Project.Structure.Bars.GetMany(BarSelection)
Rafal Gaweda
Message 57 of 64
Sorry, I have a problem.
When i click in Update objects appears:
What I do?
Thanks.
Message 58 of 64
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
My guess is You are running more than 1 Robot at the same time while using this macro .
API macros \ addins work fine only while 1 Robot is running.
Rafal Gaweda
Message 59 of 64
Thanks for your answer.
I only have one robot running.
The version of robot is 2016, have any problem?
Message 60 of 64
Hi, have you found solution?
