Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Timber memeber type not available
5 REPLIES 5
988 Views, 5 Replies
I recently downloaded and installed Robot 2016
But I cannot define any elements to be a "timber member type"
I tried this solution
 http://forums.autodesk.com/t5/robot-structural-analysis/timber-design-member-type/m-p/5874711/highli...
and it seamed to work
However when I tried the same fix on another computer, it did not solve the issue.
What can I do to solve this problem?
Tags (1)
5 REPLIES 5
Artur.Kosakowski
Try to rename your CfgUsr (to e.g. 1CfgUsr) folder:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2016\CfgUsr\
Artur Kosakowski
in reply to: Artur.Kosakowski
Thank you for the quick reply, but It did not help
Artur.Kosakowski
Could you attach a sample model and screen capture that illustrates what exactly you tried to do and what didn't work as expected please? Thank you.
Artur Kosakowski
A student found this solution. So I think we solved the problem.
Artur.Kosakowski
I'm glad it worked. Thank you for posting this solution.
Artur Kosakowski
