Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Special beam profile and offset
4 REPLIES 4
571 Views, 4 Replies
Dear users,
I have a beam (the z shaped one on the figure), which is made from 3 steel plates. I have columns up and down which are on the middle of the top and bottom plates originally.
My question is: Is it a good idea to model it in a way, that I make that z shape profile and draw as beam. After I attach the columns in the middle of the whole z profile and apply offsets up and down as they should be in reality? Because I am also curious about the bending moments, etc.
Thanks in advance !
4 REPLIES 4
Artur.Kosakowski
Personally I'd rather use rigid links instead.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thank you Artur for your suggestion! May I ask why you would prefer that solution?
In addition let me ask which way is prefered for such a rigid link?
Or it doesn't matter how the rogod link is formed withing the beam?
Artur.Kosakowski
The rigid link connects a master node with slave nodes therefore you cannot have it as a Z shape. Personally I'd define a node of a beam as the master one and columns' nodes as slaves. but assuming that it is a fully fixed rigid link in fact it doesn't matter which of these nodes is the master one. The reason I prefer rigid links is the obtained forces are based on exact shape of deformation.
Artur Kosakowski
