I recently downloaded and installed Robot 2016
But I cannot define any elements to be a "timber member type"
I tried this solution
and it seamed to work
However when I tried the same fix on another computer, it did not solve the issue.
What can I do to solve this problem?
Try to rename your CfgUsr (to e.g. 1CfgUsr) folder:
C:\Users\username\AppData\Roaming\Autodesk\Autodes
Could you attach a sample model and screen capture that illustrates what exactly you tried to do and what didn't work as expected please? Thank you.
A student found this solution. So I think we solved the problem.
I'm glad it worked. Thank you for posting this solution.
