Robot 2023/2024 freezes when switching GUI language
netsonicyxf
Message 1 of 16
netsonicyxf
It jusr freezes, and it's CPU usage is 11% (Intel 8700k) as if it's under heavy analysis task.
Replies (15)
Message 2 of 16
okapawal
Hi @netsonicyxf
When does the program  freeze?
You should see the message that steel design code parameters will be changed and then that the program will be restarted.
Can you see these warnings?
Waldemar Okapa
Sr Product Owner
Message 3 of 16
netsonicyxf
@okapawal
Yes, I saw this message, I pressed "OK" butten, then Robot freezed and never restart.
I tried unintsalling and reinstalling, but it doesn't sovle the issue.
Message 4 of 16
netsonicyxf
What should I do to fix it?
Message 5 of 16
okapawal
Frankly speaking this is the first time I've ever seen such an issue.
Does it change the language when you kill the process and start the program again?
Does your user name include some special non-latin characters?
You may try to delete your local user data folder
C:\Users\your_login\AppData\Roaming\Autodesk\Robot Structural Analysis Professional 2023\CfgUsr
Waldemar Okapa
Sr Product Owner
Message 6 of 16
netsonicyxf
1. It doesn't change the language when I kill the process and start the program again
2. My windows user name composes of tree English letters.
3. Deleteing the local user data folder
doesn't help.
BTW, it never recreate itself when I kill the process and start the program again.
Message 7 of 16
Romanich
Hi @netsonicyxf,
What language do you need to switch to?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 8 of 16
netsonicyxf
to English (United States)
Message 9 of 16
Romanich
Try the attached file.
Roman Zhelezniak
Message 10 of 16
netsonicyxf
When I clicked "Switcth to English", it shows "Open robot and load the model".
Then I opened Robot and creat a new model, it's the same language as before.
Any way, Thank you
Message 11 of 16
Romanich
Hi @netsonicyxf ,
You should run the robot with some model (or empty model) and run the macro. Then close Robot and open it again.
Roman Zhelezniak
Message 12 of 16
netsonicyxf
It works! Thank you.😄
Message 13 of 16
yidan_cao
Observer
Observer
Hi, I'm having the same problem I can't get it resolved
Message 14 of 16
netsonicyxf
@Romanich
The Robot 2025 has the same issue and it can be resolved by the same solution. Thank you.
When trying to switch either regional setting or printout language in Robot 2023~2025, they still freeze.
I want to
1. switching to "eurocode" and "united states" in regional setting
2. switching to "English" in printout language
Do you have the (VBA) solutions to these two issues as well? Thank you.
Message 15 of 16
tangld500
same problem with both version of 2023 and 2025. 😂😂
Message 16 of 16
tangld500
Finally, I get this walkaround solution:
Adding these two lines of codes to the original script will set your Printout language to English and Reginal setting to US
RobApp.Kernel.Preferences.SetLanguage IRobotLanguage.I_L_PRINTOUT, 1
RobApp.Kernel.Preferences.SetLanguage IRobotLanguage.I_L_REGIONAL, 1
Launch the macro as mentioned above, ie launch a random calculation then the macro.
Now, if you want to change Reginal settings so that the section database, code etc can follow accordingly.
I cancel the "update Preferences on exit" option and leave both language settings untouched (change language only with the macro, otherwise it will freeze again).
Sometimes it will bug again after switching region and relaunch robot.
(I can't figure out why. Error msg shows sth like "on going process, blabla". Maybe should kill the excel file before relaunching robot.)
Simply sign out and login again (No need for reboot).
