Robot 2023/2024 freezes when switching GUI language
13 REPLIES 13
Message 1 of 14
netsonicyxf
745 Views, 13 Replies
It jusr freezes, and it's CPU usage is 11% (Intel 8700k) as if it's under heavy analysis task.
13 REPLIES 13
Message 2 of 14
okapawal
in reply to: netsonicyxf
Hi @netsonicyxf
When does the program  freeze?
You should see the message that steel design code parameters will be changed and then that the program will be restarted.
Can you see these warnings?
Waldemar Okapa
Sr Product Owner
Message 3 of 14
netsonicyxf
in reply to: okapawal
@okapawal
Yes, I saw this message, I pressed "OK" butten, then Robot freezed and never restart.
I tried unintsalling and reinstalling, but it doesn't sovle the issue.
Message 4 of 14
netsonicyxf
What should I do to fix it?
Message 5 of 14
okapawal
Frankly speaking this is the first time I've ever seen such an issue.
Does it change the language when you kill the process and start the program again?
Does your user name include some special non-latin characters?
You may try to delete your local user data folder
C:\Users\your_login\AppData\Roaming\Autodesk\Robot Structural Analysis Professional 2023\CfgUsr
Waldemar Okapa
Sr Product Owner
Message 6 of 14
netsonicyxf
1. It doesn't change the language when I kill the process and start the program again
2. My windows user name composes of tree English letters.
3. Deleteing the local user data folder
doesn't help.
BTW, it never recreate itself when I kill the process and start the program again.
Message 7 of 14
Romanich
Hi @netsonicyxf,
What language do you need to switch to?
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 8 of 14
netsonicyxf
in reply to: Romanich
to English (United States)
Message 9 of 14
Romanich
Try the attached file.
Roman Zhelezniak
Message 10 of 14
netsonicyxf
When I clicked "Switcth to English", it shows "Open robot and load the model".
Then I opened Robot and creat a new model, it's the same language as before.
Any way, Thank you
Message 11 of 14
Romanich
Hi @netsonicyxf ,
You should run the robot with some model (or empty model) and run the macro. Then close Robot and open it again.
Roman Zhelezniak
Message 12 of 14
netsonicyxf
It works! Thank you.😄
Message 13 of 14
yidan_cao
Hi, I'm having the same problem I can't get it resolved
Message 14 of 14
netsonicyxf
@Romanich
The Robot 2025 has the same issue and it can be resolved by the same solution. Thank you.
When trying to switch either regional setting or printout language in Robot 2023~2025, they still freeze.
I want to
1. switching to "eurocode" and "united states" in regional setting
2. switching to "English" in printout language
Do you have the (VBA) solutions to these two issues as well? Thank you.
Technology Administrators
