Direct integration with revit 2025 is not working
gporrasm1
Message 1 of 8
gporrasm1
Community Visitor
Community Visitor
Hello, I am trying to send a model to revit 2025, but it does not allow me to do it, by direct way, it just gives me the .smxx option, that in fact I don´t know how to send to Revit.
Does anyone have this trouble and solved it?
Thank you very much
Replies (7)
Message 2 of 8
okapawal
Starting from version 2025 direct integration is available form Revit side only.
Open your model in Robot Structural Analysis program.
Run Robot Structural Analysis Link from Analyze tab in Revit ribbon.
Click Update Model and accept with OK button.
Waldemar Okapa
Sr Product Owner
Message 3 of 8
civ.ammar
Hello
When I try to send model from revit to robot I receive this message..
Could not load file or assembly 'Autodesk.Common.AResourcesControl, Version=38.0.0.11069, Culture=neutral, PublicKeyToken=ff3304d4f320ee59'. Uncaught exception during type initialization. (0x80131534)
Also I sent a screenshoot in the attachments.
Can you help me please..
Message 4 of 8
umut.akparlar
@civ.ammar
Message 5 of 8
okapawal
Message 6 of 8
pierre
I am a developer and my application calls some functions defined in Rex.ContentGenerator.dll
With all past Revit releases, it has worked fine, but with Revit 2026, the call to New REX.ContentGenerator.Converters.RVTFamilyConverter(pApplication.ActiveUIDocument.Document, True) throws the following exception:
Could not load file or assembly 'Autodesk.Common.AResourcesControl, Version=38.3.0.11109, Culture=neutral, PublicKeyToken=ff3304d4f320ee59'. The system cannot find the file specified.
And indeed there is an older version of that DLL on my computer in "C:\Program Files\Common Files\Autodesk Shared\Extensions 2026\Common\Autodesk.Common.AResourcesControl.dll"
Can you help me locate the newest version?
Thanks for your help,
Pierre
Message 7 of 8
okapawal
Hi @pierre
Have you installed Preview version before?  Check this post
Unable to send model from Revit 2025 to Robot 2025 - Autodesk Community
Waldemar Okapa
Sr Product Owner
Message 8 of 8
SakulSurendran-WPM
Observer
Observer
I was facing an issue while pushing the model from Revit 25 to Robot 25 by performing direct integration. After completing the procedure, no members have got generated in the Robot instead i was only able to successfully push the story levels from the Revit to Robot. I have created the analytical model by using Analytical automation tool in Revit 25 before performing the direct integration.
Can someone please help me with this?
Thanks!
