Unable to send model from Revit 2025 to Robot 2025
civ.ammar
civ.ammar
Hello
When I try to send model from revit to robot I receive this message..
Could not load file or assembly 'Autodesk.Common.AResourcesControl, Version=38.0.0.11069, Culture=neutral, PublicKeyToken=ff3304d4f320ee59'. Uncaught exception during type initialization. (0x80131534)
Also I sent a screenshoot in the attachments.
Can you help me please..
okapawal
Hi @civ.ammar
Did you have installed Preview versions before on this machine?
The issue may be caused by incompatibility of some shared components.
Could you please check what is the version number and date of the following file:
"C:\Program Files\Common Files\Autodesk Shared\Extensions 2025\Common\Autodesk.Common.AResourcesControl.dll"
Go to this location, click the file, and call properties from the context menu:
Waldemar Okapa
Sr Product Owner
okapawal
I'm afraid you need to reinstall the link extension and both products Revit and RSA to make it working properly.
  1. Uninstall "ExtensionForRevitAndRobotStructuralAnalysis" (and Robot-Advance Steel Link 2025)
  2. Uninstall RSA 2025
  3. Uninstall RVT 2025
  4. (Uninstall INV 2025)
  5. Check if "C:\Program Files\Common Files\Autodesk Shared\Extensions 2025" exists.
  6. If exists, delete this folder.
  7. Install RVT, RSA, Extension (and others) again .
Waldemar Okapa
Sr Product Owner
ouni_kamel
Community Visitor
Community Visitor
Bonjour
Comment peut-on activer l'intégration directe ?
