Hi @Djokaboris
The huge displacement is caused by no supports on the elevator. Just from inserting it Sir.
You can’t add supports at elevators, because you’ll change structure behavior. You may use some Kz percentage for Kx ad Kx to simulate raft-soil friction.
For the beams and columns, i don't have problems with it because i can easily size and design it in the RC design GUI without errors.
This is not correct. Using dummy beams and columns will affect slabs and raft design. Raft punching, slabs reinforcement and deflection will not be correct.
For example warning about "Punching force is too big" is due to columns section or raft thickness or both
I recommend you to take some time to define your structure with real elements before trying to design.
M. Agayr
