Load takedown on floating columns
Djokaboris
Message 1 of 28
Djokaboris
Hi;
Just from doing the loadtakedown on column in RSA, and why do RSA doesn't take into account the floating columns and many others columns during the load takedown?. Even for the corner columns, the moment(M)  is not taken into accounts. I'm i right or there's a workaround to get this result. Need a hand in this 🙏.
Replies (27)
Message 21 of 28
Djokaboris
For the basement on one side, its due to the form of the TOPO surface. And the shear wall are due to the constraints given by the architect Sir @Simau
Message 22 of 28
Simau
Hi @Djokaboris
The huge displacement is caused by no supports on the elevator. Just from inserting it Sir.
You can’t add supports at elevators, because you’ll change structure behavior. You may use some Kz percentage for Kx ad Kx to simulate raft-soil friction.
For the beams and columns, i don't have problems with it because i can easily size and design it in the RC design GUI without errors.
This is not correct. Using dummy beams and columns will affect slabs and raft design. Raft punching, slabs reinforcement and deflection will not be correct.
For example warning about "Punching force is too big" is due to columns section or raft thickness or both
I recommend you to take some time to define your structure with real elements before trying to design.
M. Agayr
Message 23 of 28
Djokaboris
Hi Sir @Simau
Many thanks for your answers and recommendation. Just from including the real size of beams and columns but Robot freezes when the calculation is run.
Message 24 of 28
Simau
Hi @Djokaboris
The model works, but with remaining warnings about incoherences on edges (due to geometric inacurancies you have to fix)
You have also issues with raft punching at colomuns ompacts (Blue  is ok, green you need to add punching reinforcement and red you must increase column section or raft thickness)
M. Agayr
Message 25 of 28
Djokaboris
Hi Sir @Simau
Many thanks for the time spent on the file, but because of the errors displayed there's no FEM results.
how to solve the freezing problem, if i may ask?
Message 26 of 28
Stephane.kapetanovic
hi @Djokaboris
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/ROBOT-Error-1470-r...
Best Regards
Report deleted
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 27 of 28
Djokaboris
Hi Sir @Stephane.kapetanovic
Thanks for your help and answers. Please is there a way of having this section in Robot RC beam design GUI ??
Message 28 of 28
hi @Djokaboris
you've already asked the question here, I don't have the answer but you should try the fourth with a slab on one side only.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/design-of-an-rc-l-beam/td-p/12973446
Best Regards
