Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Load Cases / Envelope
16 REPLIES 16
Message 1 of 17
9354 Views, 16 Replies
Hello!
I created 4 wind load cases and 3 snow load cases. My problem is to create an envelope containing wind cases and another containing snow ones. Is it possible? By doing this I want to reduce the number of combinations generated my Automatic combinations module. My teacher recommended this, too.
I read that robot cant create envelopes. Is it true?
Thanks in advance.
16 REPLIES 16
Message 2 of 17
the goal - reduce the number of combinations generated my automatic combinations module?
Message 4 of 17
I was told its theoretically right to make a envelope combination - the Eurocode 1 says that. And the goal of course is reducing the number of combinations. It's a simple steel frame I don't need 200 combinations.
I've read the posts you told me but I see the only way is editing the load cases in excel? Grouping the combinations doesn't make a envelope of them, right?  Is there another way?
And if you don't understand me, I want to make a envelope as SAP2000 do it - it has a load combination type - envelope.
Message 5 of 17
200 is very little. 1 000 000 combines is normal. I use for that special program (I author). I do it for myself.
Message 6 of 17
Rafal.Gaweda
I think we do not understand you. Also, at least me, do not know what is envelope case\ combination in SAP.
Envelopes are generated automatically in Robot these ways:
Rafal Gaweda
Message 7 of 17
I want to create a envelope of 4 wind load cases and combine this envelope in ULS combinations, for example,
G+Q+0.5*envelope (Wind1; Wind2; Wind3; Wind4).
Thanks for the help. 🙂
Message 8 of 17
Rafal.Gaweda
And the result of the above is ...?
Tell me what you want to get.
Rafal Gaweda
Message 9 of 17
Tihs is a combination. I want the maximum values of the internal forces. Instead of combining dead and live loads with 4 wind load cases to be just 1. I hope I gave the right answer.
Message 10 of 17
Rafal.Gaweda
Not possible.
Rafal Gaweda
Message 11 of 17
combine 1
Axial = 100; Moment = 14 (Axial MAX)
combine 2
Axial = 14; Moment = 100 (Moment MAX)
combine 3
Axial = 99; Moment = 99( stress MAX)
Message 12 of 17
in reply to: Rafal.Gaweda
thannks for your help ?
 but how i can chose combo envelop for design RC ?
Message 13 of 17
Rafal.Gaweda
Go to Combin. tab and select combinations - if I understood you correctly
Rafal Gaweda
Message 14 of 17
Artur.Kosakowski
Hi @Anonymous
The design of reinforcement is done for each of the combinations one by one and designed reinforcement is such that it secures element's capacity for all of them.
Please see: Rc Members - Required Reinforcement - Beams
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 15 of 17
leidy.arbelaez
Pudiste hacerlo? me podrías decir como?
Message 16 of 17
leidy.arbelaez
Puedo meter una envolvente dentro de una combinación?
Message 17 of 17
Hola @leidy.arbelaez,
te animo a que si publicas en español abras un nuevo tema en los foros de la Comunidad Autodesk en Español.
Aquí te dejo el link: https://forums.autodesk.com/t5/espanol/ct-p/157
¡Hasta pronto!
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
