Hey,
I have created the load combination using the Automatic Combination (Manual Combination Generator).
For all the individual combination I am getting the right results, But When I try to select the all ULS or SLS combination I am not getting any results, I do not understand why?..
Even I am getting any result if I choose any 2 combinations also.
Please find the attachment
Thank you,
J.Randeep
Solved by Rafal.Gaweda. Go to Solution.
I could not send the model.
Attachment is not Supporting the .Rtd model.
BR,
J.Randeep
Two ways of correcting:
1.
- delete combinations
- select everything, copy to clipboard
- open new model, paste from clipboard
- generate combinations - I hope it should work with your rgl file
2.
- use attached xls file, on Basic tab use "Import..." button, do not close xls file
- delete combinations in robot
- use attached xls file again, on Combinations tab use "Generate" button
Corrected file attached
