Group the Combination?
7 REPLIES 7
Message 1 of 8
2386 Views, 7 Replies
Hey,
I have a more that 2000 combination generated using Automatic Combination-------manual Combination Generate..
Is there a way to group the certain combination that I am intereted in.
So I do not need to choose every time from select load case componenet
Thank you,
J.Randeep
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
Yes, you can create such group(s) in the way shown on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 8
Hey,
Please find the attachment.
Where in the Selection dialogue box for the cases there I a option for group.
But how to group them?
Thank you,
J.Randeep
Message 4 of 8
Artur.Kosakowski
Have you managed to read my answer before you posted this question or not? Both came in the same time so I'm not sure.
Artur Kosakowski
Message 5 of 8
Hey,
Thank you
BR,
J.Randeep
Message 6 of 8
Hey,
I got your answer..I posted it before I saw your reply.
BR,
J.Randeep
Message 7 of 8
Hey,
It Is working..But It is not showing group in the list as your example which you have sent me before..
I have marked them. Please find the attachement.
BR,
J.Randeep
Message 8 of 8
Artur.Kosakowski
Most likely it is some refreshing issue with the list of loads. The group may not be visible directly after you created it. It should be enough to switch to another layout or even expand the list for the second time. Otherwise save the file with a new name and open it again.
Artur Kosakowski
