I tried to create a eccentricity to move 25 mm my column, this to align edge (1) with the edge (2) moving like (3) but not luck, I tried modify each option but do nothing to move 25 mm offset in axis X direction (in the file attached)
... and if possible someone could suggest me any e-book or course to learn robot structural? I did not find many documentation, not sure what do each button
Solved by Refaat. Go to Solution.
Solved by Mohammed_Ata. Go to Solution.
Solved by Romanich. Go to Solution.
Hi @jtm2020hyo ,
Did you check the links from the post below?
https://forums.autodesk.com/t5/robot-structural-analysis-forum/manual-for-robot/m-p/9498765#M81506
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
You can offset your column with offset. You can see some options in this tutorial
52 - Robot Structural Analysis Professional - Eccentricity of beams and columns
Keep us updated
Mohammed Ata
Structural Design Engineer
Autodesk Expert Elite
Book , take a look here !!!
thanks for all the help, @Refaat @Mohammed_Ata @Romanich, I was checking all links but I did not found a direct solution or mention to this issue (I used ctrl+F)...
... but I was lucky this time and I found the solution and was use the "Offset > Coordinate system > Global" option and this was not documented anywhere. I hope this post help anyone in the future
PD: How can I make the signature in the footer as you all do in the Autodesk forum?
If any replies satisfied your question, please accept it as a solution.
Mohammed Ata
