wind pressure mapping
JPNR87
JPNR87
I generated wind simulation and afterwards deleted all loads.
Wind mapping is still in model and foundation reactions confirm that .
How to remove wind loads
Thanks!
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @JPNR87
After model modification (deleting load) calculate model again . Loads should not be visible any more
Krzysztof Wasik
JPNR87
Deleted loads and pressure map disapeared. However I mentioned that wind loads were still in model according to foundation reactions - No they werent! Be aware, that cable prestress (assembly) loads are allways in 1 load case and presented as default in other load cases. I forgot that :S
Thanks!
