Please check whether the analytical model is okay for the analysis in ROBOT or ETABS
There were offset in beam and floor. To adjust a beam at column edge, I have applied analytical links.
Since, I have not applied footing below column, it pops warning that columns are not supported. But I fail to understand, why Revit says beams are not supported. (ref 210323_model)
I have imported model in ETABS. During analysis it says that structure is unstable
I have attached the model and would grateful if you can point me the issues.
