Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
How to add a offset to any object?
5 REPLIES 5
jtm2020hyo
538 Views, 5 Replies
I tried to create a eccentricity to move 25 mm my column, this to align edge (1) with the edge (2) moving like (3) but not luck, I tried modify each option but do nothing to move 25 mm offset in axis X direction (in the file attached)
... and if possible someone could suggest me any e-book or course to learn robot structural? I did not find many documentation, not sure what do each button
5 REPLIES 5
Romanich
in reply to: jtm2020hyo
Hi @jtm2020hyo ,
Did you check the links from the post below?
https://forums.autodesk.com/t5/robot-structural-analysis-forum/manual-for-robot/m-p/9498765#M81506
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Mohammed_Ata
You can offset your column with offset. You can see some options in this tutorial
52 - Robot Structural Analysis Professional - Eccentricity of beams and columns
Keep us updated
Mohammed Ata
Structural Design Engineer
Autodesk Expert Elite
Refaat
jtm2020hyo
thanks for all the help, @Refaat  @Mohammed_Ata  @Romanich, I was checking all links but I did not found a direct solution or mention to this issue (I used ctrl+F)...
... but I was lucky this time and I found the solution and was use the "Offset > Coordinate system > Global" option and this was not documented anywhere. I hope this post help anyone in the future
PD: How can I make the signature in the footer as you all do in the Autodesk forum?
Mohammed_Ata
@jtm2020hyo
If any replies satisfied your question, please accept it as a solution.
Mohammed Ata
