Frame Calculator
Frame Calculator
Frame Calculator
I am an engineering student and I am currently looking for a frame calculator. But I saw this free online frame calculator and it promised to generate and find the bending moment and shear force diagrams of a 2D frame structure. Is there anyone here has tried using their software? Hope to hear from you soon. thanks!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not familiar with it but in RSA there is a frame generator as well (Add -ins > Frame Generator)
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Thanks for your prompt reply. I will have a look. Is the frame generator you mentioned also from autodesk? Also, is the software for free? Thank you! 🙂
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
It is a tool available inside RSA whcih is a free program for students.
See: https://www.autodesk.com/education/free-software/featured
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Cool. Great help. Thanks!
colleencamacho59
@Anonymous wrote:
I am an engineering student and I am currently looking for a frame calculator. But I saw this free online james smith deficit calculator and it promised to generate and find the bending moment and shear force diagrams of a 2D frame structure. Is there anyone here has tried using their software? Hope to hear from you soon. thanks!
It is calculated as the perpendicular force multiplied by the distance from the point. A Bending Moment is simply the bend that occurs in a beam due to a moment.The bending moment (BM) is defined as the algebraic sum of all the forces' moments acting on either side of the section of a beam or a frame. This is a graphical representation of the variation of the shearing force on a portion or the entire length of a beam or frame.There are seven typical methods of bending in the industry: induction bending, rotary-draw/compression bending, roll bending, plate rolling, point bending / gag pressing, synchronized incremental bending, and hot bending (using induction or other heating sources).
