Revit foundation in Robot is taken as Fixed Support
hello,
i draw an isolated foundation in REVITstructure (120/180/45 cm) but when i send the model to ROBOT its become a fixed support.
i clicked on the foundation and clicked DESIGN->PROVIDED RIENFORCEMENT ON RC ELEMENTS but the basic dimensions is not the same as i set in REVIT .
i changed it and go to calculation and again the ROBOT reset the dimensions.
is there a way to make ROBOT get data of foundation from REVIT ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
No, the size of the foundation as defined in Revit is not transferred to RSA. The assumption is that you actually don't know the size of the foundation at this stage and you want to design it in Robot. Anyway to avoid the size of the foundation to be optimized in RSA just marked the fixed check boxes after setting them as in Revit in the RSA dialog you displayed and press the Apply button.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
