How and when we need to use Dilatation Load?
Iron.Max.Steel
Iron.Max.Steel
Sorry to ask just now encounter this term, I have used other software but I did not found this type of loadings maybe It just a different terms.
Well, please anyone kindly please help me to explain how and when I need going to use this type of loading in bar?
Thank you In Advanced!
mustafahesenow
Hi @Iron.Max.Steel
This option to specify the exact elongation or shortening in bar and to get the exact axial force will cause this dilatation.
In another words >
Lets say you have a bar and you apply on it 100 KN as axial compression force as a  result  you get axial deformation in the bar 1mm. If you want to know what the force will cause 5 mm in this bar apply dilatation 5mm on this bar and from bar diagram you will know what force cause that .
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Iron.Max.Steel
Hi @mustafahesenow
Wow, what a nice feature. Thank you for your detail explanation. ROBOT IS THE BEST!!!
mustafahesenow
you are always welcome brother.
Mustafa Hesenow
LinkedIn
