Mesh not visible near edge of panel
Mesh is not visible near the edge of a panel. I though it was skipped but when I exported the panel in a separate file as a substructure i could see the mesh along the edge. In the main file it is not appearing though. I hope it would not affect my results.
Rehan
mustafahesenow
Hi @Anonymous
What version of RSA you use ?
Can you send us the model please ?
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Hi Mustafa,
I am using Robot 2018. My system is 64 bit Core i7 with 32gig RAM and 4 gig Nvidia Quadro.
The problem went away by itself next day when i loaded the model. The file is too heavy to send. It happens on heavy models though.
I think it is just graphics not the analytical model itself.
Thanks.
Rehan.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Make sure you switched off the Story filter.
You can send the link to your model in thsi way
https://forums.autodesk.com/t5/robot-structural-analysis-forum/sending-bigger-files/td-p/3795062
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Thanks Artur,
It was because of the Story Filter. I turned it off and it was okay.
Rehan
