ARC SLAB ON ARC WALL
5 REPLIES 5
risefire12
992 Views, 5 Replies
im trying to model arc slab on arc wall with arc discritizaton, but the joints are not connected to each other.
and also it give two joints at the same position
so what might be the problem ?
5 REPLIES 5
Romanich
in reply to: risefire12
Hi @risefire12 ,
You have a different discretization for arc segments:
Please check this topic.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Distorted-Elements-and-Mesh-Error/td-p/38238...
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
risefire12
in reply to: Romanich
thank you very much for your reply.
i did set the discretization for floor to 7 same as the wall.. but still same problem
hi @risefire12
same workaround, split the circular edge into multiple arcs of the same radius and redo the vertical panels
Best regards
hi @risefire12
below, Split Arcs, a program to split all arcs of a contour, polyline, arc.
To use it, set the maximum length, select a contour (panel or cladding), a polyline or an arc and click ok
this program cuts each arc to the maximum length including if checked, the selected nodes. (see this short demo)
Best regards
Released 21/10/2023
