ARC SLAB ON ARC WALL
risefire12
risefire12
im trying to model arc slab on arc wall with arc discritizaton, but the joints are not connected to each other.
and also it give two joints at the same position
so what might be the problem ?
Romanich
Hi @risefire12 ,
You have a different discretization for arc segments:
Please check this topic.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Distorted-Elements-and-Mesh-Error/td-p/38238...
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
risefire12
thank you very much for your reply.
i did set the discretization for floor to 7 same as the wall.. but still same problem
Stephane.kapetanovic
hi @risefire12
same way, split the circular edge into multiple arcs of the same radius and redo the vertical panels
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
hi @risefire12
below, Split Arcs, a program to split all arcs of a contour, polyline, arc.
To use it, set the maximum length, select a contour (panel or cladding), a polyline or an arc and click ok
this program cuts each arc to the maximum length including if checked, the selected nodes.
(view in My Videos)
Best regards
Released 26/09/2024
Rafal.Gaweda
Autodesk Support
Autodesk Support
