Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API Tutorial
24 REPLIES 24
Message 1 of 25
Rafal.Gaweda
30502 Views, 24 Replies
API Tutorial
Install SDK and look for Tutorial.
I am also attaching API tutorial here.
Rafal Gaweda
24 REPLIES 24
Message 21 of 25
in reply to: Rafal.Gaweda
Hi friend, could you please send me the codes to be able to design a foundation from a macro created from visual basic for plaicaciones ?; I from this code "Dim RobApp As RobotApplication Set RobApp = New RobotApplication If Not RobApp.Visible = True Then Set RobApp = Nothing MsgBox "abrir robot" Exit Sub End If 'RobApp.Project.New I_PT_FOUNDATION" I can only get to a part, which is almost nothing, and I would like to completely design a foundation through a macro, please help me and thank you very much
Message 22 of 25
Hello friend, a favor, I want to make a macro
in visual basic for applications to design a
foundation with the structural robot but I can not find the right
codes, please send me the codes for this sequence
Through this code "Dim RobApp As RobotApplication
 Exit Sub
RobApp.Project.New I_PT_FOUNDATION" I can get to this image:
And I would like to come to this:3.png
And finally the codes can be sent to change some parameters like admissible capacity, dimensions of
the founding, etc. thank you very much
for your support
Message 23 of 25
Rafal.Gaweda
Message 24 of 25
Excuse me, what code can I use in a macro to indicate the length of the coating, the allowable capac- ity, the number of the steel rod to be used, etc., for a foundation, thank you very much for your help
Message 25 of 25
Building RESTful web services, like other programming skills is part art, part science. As the Internet industry progresses, creating a REST API becomes more concrete with emerging best practices.
Technology Administrators
