(API) Spider - the multi-tool with rigid links
Romanich
Mentor Mentor
Message 1 of 43
Romanich
I would like to present my new addon - the Spider. It will help you to create rigid links for multiple column-slab joints, multiple beam-wall joints, create rigid links along beam length and finally create drop panels and connect them to the slab by rigid links.
This video will give you an understanding about possibilities of the Spider
Please visit http://spider.structuraldesign.pro, fill the form and get your Spider today.
Thanks!
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (42)
Message 2 of 43
Rafal.Gaweda
Autodesk Support
Autodesk Support
Roman,
Respect.
I will add it to our addon list
Rafal Gaweda
Message 3 of 43
Rafacascudo
Very good Romanich!!! Congrats!!!
Rafael Medeiros
Message 4 of 43
napooil
It's awesome. Romanich
Message 5 of 43
Refaat
Dear Roman
Very helpful tool  ... Thank you very much  Smiley Happy
Best Regards
Refaat
Message 6 of 43
Simau
I went to the indicated link, but could not send message for download .
What is the purpose of the 4th row?
M. Agayr
Message 7 of 43
Romanich
Hi, the 4th row is a CAPTCHA. You should solve 0/18949 and input the answer.
Roman Zhelezniak
Message 8 of 43
Simau
M. Agayr
Message 9 of 43
HoshangMustafa
Hi
While filling the form, this message came:
The download link will be delivered directly to your indicated email
 but I didn't receive any.
Message 10 of 43
Romanich
During the last three months, the Spider has been significantly modified and improved. Based on that, I am proud to present the Spider Pro – professional multi-tool for professionals who use Autodesk Robot on the daily basis.
The list of new features:
• User can input the number of nodes along sides of the column on the Column tab
• Beam to wall connection on the Beam tab now is possible for any cross section of the beam with the height indicated by User
• The brand-new Bar 3D tab allows a User to create spiders for any bars in the 3D space
• User can create rigid links along the length of the bar to connect bars to panels or to connect panels with panels on the brand-new Bar to Panel tab
• User can easily modify length of the selected bars on the brand-new Extender tab
Please watch this short video to be aware of how all new features are working https://www.youtube.com/watch?v=N0SPGyPY3A0
If you are interested in the purchasing of the Spider Pro, please visit http://spider.structuraldesign.pro and fill the form.
The development of the Spider Pro continues and soon you will see new implemented amazing features which will get you free from the monotone and boring manipulations in Robot.
Roman Zhelezniak
Message 11 of 43
HectorDuenas
The spider looks great!!.
Do yo think it can work in a Robot Millennium v20.1.5 (2007)?
Regards
Hector Duenas
Message 12 of 43
Romanich
Hi Hector,
I'm not sure regarding old versions of Robot. With RSA 2016-2018 the Spider works great. Anyway, you can try 😉
Roman Zhelezniak
Message 13 of 43
great tool! well done
Message 14 of 43
Romanich
The development of the Spider Pro continues and today I would like to reveal the list of new features in Spider Pro v.1.1:
Now it is possible to create rigid links along selected side of the column through the center line on the Column tab
• User can easily convert selected columns to walls on the Modifier tab
• User can convert ALL rigid links in the model to bars with the predefined section on the Modifier tab
Please watch this short video to be aware of how all new features are working in Spider Pro v.1.1- https://youtu.be/3AjyvSp36t4
Roman Zhelezniak
Message 15 of 43
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thank you Smiley Happy
Artur Kosakowski
Message 16 of 43
Hello
I am running Windows 10 Pro 64-bit operating system with the lastest Creators Update installed (Version 1703).
When trying to install Spider the following message comes up:
Is this a common issue? Is there a workaround?
Tiago
Message 17 of 43
Romanich
Hi Tiago,
I have exactly the same configuration of operating system and I have no problems.
Roman Zhelezniak
Message 18 of 43
Romanich
What's new in Spider Pro v.1.2:
• Now it is possible to automatically adjust distance between nodes depending on the FE size on the Column tab
• User can create nodes in characteristic points of contours on the Modifier tab
Please watch this short video to be aware of how all new features are working in Spider Pro v.1.2- https://youtu.be/gSvcnQ46WBs
Roman Zhelezniak
Message 19 of 43
Muhammed.OPERA
Really awesome Add-on
it's very very helpful
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 20 of 43
suppose i buy this for me. Will i be able to use single setup in multiple systems or it is for 1 pc only ?
