Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Void Extrusion
2 REPLIES 2
elky853
609 Views, 2 Replies
Void Extrusion
I'm trying to create a void extrusion to a certain wall in a project. The only way I can see it properly is in elevation/section/3d view, but I'm getting an error msg that the 'work plane is at a very sharp engle'. Any solutions? Thanks!
Tags (1)
Labels (3)
2 REPLIES 2
MostafaElashmawy
in reply to: elky853
Hi @elky853 ,
In the required view and before modelling the void, click on "Set Work plane" and select a surface to draw the void on it (The wall surface)
Mostafa Elashmawy
elky853
in reply to: MostafaElashmawy
Thanks so much @MostafaElashmawy !! Appreciate your help
Forma Design Contest
