I'm trying to create a void extrusion to a certain wall in a project. The only way I can see it properly is in elevation/section/3d view, but I'm getting an error msg that the 'work plane is at a very sharp engle'. Any solutions? Thanks!
Solved by MostafaElashmawy. Go to Solution.
Hi @elky853 ,
In the required view and before modelling the void, click on "Set Work plane" and select a surface to draw the void on it (The wall surface)
Mostafa Elashmawy
