Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel connections - IFC exporter
2 REPLIES 2
robert.jungergard
481 Views, 2 Replies
I have downloaded the latest IFC exporter from https://apps.autodesk.com/RVT/en/Detail/Index?id=8986482933300179260&appLang=en&os=Win64.
I have tried to export some steel connections but the connections does not appear in my export. See the picture below.
The first two beams and columns has a steel connection. The third one to the far right is a control unit to compare the others with. You can see that I have “include steel elements” checked but it does not appear. I have set my steel connections to “IfcBuildingElementProxy” in IFC options.
How should I proceed?
EDIT:
An update, I have received from a IFC exporter developer that this problem still exist in R2020 unfortunaly. I work in R2020 and I don't have the time or mandate to upgrade my project to R2021 or R2022.
Thank you
Robert
2 REPLIES 2
in reply to: robert.jungergard
I have no issue exporting to IFC using Revit 2022 built-in IFC exporter.
robert.jungergard
in reply to: ToanDN
Hi Toan,
We can close this thread
Forma Design Contest
Technology Administrators
