Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel connections - face based families on a column loses associated host
2 REPLIES 2
robert.jungergard
278 Views, 2 Replies
I have a column where I have applied some steel connections, converting the column to a fabrication of some sort.
I have a face-based family (base plate) at the bottom of the column. When I change my base offset on my column, the face-based family loses it's associated host (the column) and doesn't move with the column.
Is this intended to be like this?
I can't use the default steel connection base plate, since my base plate is more complex than the default.
I can't find the disclaimer about this in the link below.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...
Thank you,
Labels (1)
2 REPLIES 2
edit your column family , align your base plate to reference plane level and lock or post your family here so we can check. thanks
Hi, attached is the column family and my base plate.
Forma Design Contest
Technology Administrators
