I have a column where I have applied some steel connections, converting the column to a fabrication of some sort.
I have a face-based family (base plate) at the bottom of the column. When I change my base offset on my column, the face-based family loses it's associated host (the column) and doesn't move with the column.
Is this intended to be like this?
I can't use the default steel connection base plate, since my base plate is more complex than the default.
I can't find the disclaimer about this in the link below.
Thank you,
edit your column family , align your base plate to reference plane level and lock or post your family here so we can check. thanks
Hi, attached is the column family and my base plate.
