Hello everybody,
Our firm is trying to replicate formwork plans for a foreign customer. He wants the plans to look similar to the posted screenshot. Our problem is that we can't find a way to show the walls from the above level with a pattern. Is there a way to do that in Revit?
Every advice will be greatly appreciated!
Solved by PavelAnd. Go to Solution.
lets just star basic here, have you set up your material to show the proper surface/cut pattern. Or you could apply a filter to adjust the look of the walls above.
