Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit structure Walls above
4 REPLIES 4
engaykov
1288 Views, 4 Replies
Hello everybody,
Our firm is trying to replicate formwork plans for a foreign customer. He wants the plans to look similar to the posted screenshot. Our problem is that we can't find a way to show the walls from the above level with a pattern. Is there a way to do that in Revit?
Every advice will be greatly appreciated!
Tags (1)
Labels (1)
4 REPLIES 4
PavelAnd
in reply to: engaykov
Hi @engaykov. You can make underlay with above level and then override graphics for walls above.
Best regards, Pavel Plotitsyn.
Jason.P
lets just star basic here, have you set up your material to show the proper surface/cut pattern. Or you could apply a filter to adjust the look of the walls above.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
If it helped you, mark the answer to help other users.
FeeopEngr
in reply to: PavelAnd
Excellent. We tried for an hour today to get this to work. Thx
Feeop
Forma Design Contest
Technology Administrators
