Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Rebar visibility in cut sections
9 REPLIES 9
Message 1 of 10
andre.micka
1448 Views, 9 Replies
I am trying to create a rebar drawing with revit 2022.
I use the new feature of revit 2022 that allow to have different spacing in a set.
I created a rebar set and remove some when I have a hole in the floor.
But as you can see on my cut 3, the rebar is visible despite the delimitation of the cut.
Is it possible to hide automatically the unvisible set in the view without doing it manually ?
Because if it is inevitable it is really out of control when you have lot of cuts on a big project.
Thank you
9 REPLIES 9
Message 2 of 10
I was also interested. Can you upload a test file? I will try to help you.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Message 3 of 10
Here you go
Message 4 of 10
Actually this is a problem, you can post this in Revit Idea to fix it in future updates․
Arman Margaryan
Linkedin | Facebook
Message 5 of 10
ahjorn
in reply to: andre.micka
I'm honestly not too sure as to why this is the behaviour of the rebar but you may simply hide it in the view if that is what you wish.
Message 6 of 10
andre.micka
in reply to: ahjorn
The problem is when you have a lot of views, it is impossible to verify again each view when you add a bar...
Message 7 of 10
I am not surprised. This issue occured since previous versions but noone want to have a look at it.
You can check this issue (or problem?) by drawing a set of rebar with distance 200 mm. Make a section between 2 nearest rebars and make the section's depth smaller than the distance of the rebar set. Voila, you still can see the rebar in the section.
Message 8 of 10
You click on the rebar that you don't want to see and go to the Properties window > Graphics > View Visibility States > Edit > uncheck the desired view.
Only vertical rebar will go away but I think the best way to hide other things is to create a filter to hide everything else.
Message 9 of 10
semi
the same thing happens when you change some rebars in the same set to another location, in section you will still see them in the original position
Message 10 of 10
user01_design
Funciona se utilizar elevações ao invés de cortes.
Forma Design Contest
