I am trying to create a rebar drawing with revit 2022.
I use the new feature of revit 2022 that allow to have different spacing in a set.
I created a rebar set and remove some when I have a hole in the floor.
But as you can see on my cut 3, the rebar is visible despite the delimitation of the cut.
Is it possible to hide automatically the unvisible set in the view without doing it manually ?
Because if it is inevitable it is really out of control when you have lot of cuts on a big project.
Thank you
Solved by ArmanMargaryan. Go to Solution.
I was also interested. Can you upload a test file? I will try to help you.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Actually this is a problem, you can post this in Revit Idea to fix it in future updates․
Arman Margaryan
I'm honestly not too sure as to why this is the behaviour of the rebar but you may simply hide it in the view if that is what you wish.
I am not surprised. This issue occured since previous versions but noone want to have a look at it.
You can check this issue (or problem?) by drawing a set of rebar with distance 200 mm. Make a section between 2 nearest rebars and make the section's depth smaller than the distance of the rebar set. Voila, you still can see the rebar in the section.
You click on the rebar that you don't want to see and go to the Properties window > Graphics > View Visibility States > Edit > uncheck the desired view.
Only vertical rebar will go away but I think the best way to hide other things is to create a filter to hide everything else.
the same thing happens when you change some rebars in the same set to another location, in section you will still see them in the original position
