Hello !
Does anybody know why rebars display as a sqare instead of circular when printet/exported as dwf or pdf ?
That's interesting
Could you upload a sample model showing this behavior?
Here is a Revit section model.
Could it be the video card ? we use NIVIDA Quadro K2200
Hi @galdaBZ5L9
I exported your sheet using the Adobe PDF printer and that exported correctly.
When exporting to DWF, the system is doing triangulation based on the scale of the view and the size of the circle.
I think this is a limitation of DWF export for small circles, since the same behavior can be observed for a generic model circular extrusions or even the circle end of the tag leader.
My recommendation is to use PDF or DWG.
Ovidiu
