Numbering control in text
Message 1 of 18
Greetings,
I cannot see how to start a set of plan notes with numbers, add in a space for non numbered information and then continue the numbering.
Is this possible in revit or not yet?
Replies (17)
Message 2 of 18
Yes.  Use SHIFT + ENTER to add sub-paragraph without affecting the main paragraph numbering.
Message 3 of 18
Is there a video of this being done?
Still not working the way you present it
I shift+enter once and its fine, after that I have to choose number option in the menu bar, and it restarts it with numeral 1.
Message 4 of 18
Message 5 of 18
dboudreau
Hi, What if I want to have 1 text box with some general notes....Main headers are Lettered, with indented numbers under...the next Main header always starts at A or 1..?? Is there a way to "continue" letters like in CAD?
EX:
A. first header
   1. text
  2. more text
B. second Header
  1. text
etc?? Any way to Have it go to B and to start at 1 again under B?
Thanks!
Message 6 of 18
Like this?
https://knowledge.autodesk.com/community/screencast/ae9c5f39-0639-4781-88bc-54017087756f
Screencast will be displayed here after you click Post.
Message 7 of 18
dboudreau
yes, I can't get mine to behave that way....
My B goes to A once I add my 1, 2, 3, in between...
Thank you for your help
Message 8 of 18
Did you watch the screencast? Add the space between the last number and B with SHIFT+Enter, after you have all the numbers and letters properly in order.
Message 9 of 18
dboudreau
my problem might be that I am trying to apply letters and numbers to an existing set of notes....already has formatting probably established that I can't easily overwrite
Message 10 of 18
You can always copy the notes to the side, edit and reset all the letters/numbers/bullets/spacing, then start assign them again.
Message 11 of 18
So I got the hang of this in 2018 but now in 2019 I needed non numbered spacing and did the shift+enter to create the space and the next numbered note changed to numeral 1 from numeral 2.  Now in autocad you just choose to continue when it does that.  In revit I didnt see an option for that and I cannot figure out how to get it to continue the series of numerals after the spacing.
Message 12 of 18
jtobinWDCAB
Observer
Observer
I'm finding I can get this to work by using CTRL-ENTER to add the next number, then using SHIFT-ENTER to add a space above that that does not increment. I sometimes lose the number/bullet format, but when I reapply it, it re-assumes the correct number.
Message 13 of 18
At the end of the video, you just clicked outside of the box and it remained as you edited it, when i'm doing it, it resets to the original numbering like i didn't edit anything and all lines black or filled have a number in front of them.
Message 14 of 18
jeremy.colombe
Revit 2019 allows you to change the numbers....is this new to 2019 or did I just miss it lol
Message 15 of 18
Adriana.Murillo4MX6M
Hello, what about if I want my number to not just be 1, 2, 3...
We do short form specs. and I need the numbers to be 09001, 09002, 09003 ...
Message 16 of 18
conordelalande
I would like to know how to make numbering in Revit work like this:
1. GENERAL NOTES
     1.1. NOTE
     1.2. NOTE
          1.2.1. NOTE
          1.2.2. NOTE
     1.3. NOTE
2. NOTE
Obviously I can do it manually but considering multiple A3 pages of notes I would really like the numbering to auto correct instead of me having to check and change numbering if a note is taken out half way for a particular project.
Message 17 of 18
SteveKStafford
Sorry, numbering schemes in text don't support custom numbering formats like that yet.
Steve Stafford
Message 18 of 18
dmarie58
Community Visitor
Community Visitor
I want to skip numbers for unused notes within the same list. like;
  1.  Keynote ABC
  2.  Keynote DEF
  3. this not to be 15, not 3.
Can you tell me how to do this?
