precast
precast
Message 1 of 13
precast
Hi
1- I created a precast wall using -Precast / split command/
2-i Have tried all configuration setiings.
3- But i cannot get it to put come anchor plates into my 45 degree corner connections.
 any idea will be appreciated Thanks
Replies (12)
Message 2 of 13
teodorb
Hi @Anonymous,
Are you trying to achieve this with Split command? Could you please provide the Revit model so that I have a look?
Kind regards,
Bogdan Teodorescu
Product Owner
Message 3 of 13
Thank you teodard.
1-  I am using model REVIT 2018.2
2-i just got it figured out how to put plates into my corner connections.
3-so what I want now is how do i edit my assemblies in my precast panels?
4- for instance i want my bracing  plates to be as close as possible to my split edges, it only allows me to edit my bottom to top distance and not from side to side.
5-how do i put in different type anachor plates?
   Thank you
Message 4 of 13
teodorb
Hi @Anonymous,
You can either use the families we are using or add your own families. Just position them at the desired location (if you cannot achieve this through Configuration settings) and after use the mounting parts command to add them in the assembly.
After the families are added to the assembly, you can use the reinforcement and shop drawing commands.
Let me know if you need additional information.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 5 of 13
teodorb
Hi @Anonymous,
In order to get element in the Connection section,. you need to have two walls intersecting. You can have two wall, use the wall joins command and assigned the Mitter option or it. If you do this, during segmentation you should obtain the expected result. See image.
Bogdan Teodorescu
Product Owner
Message 6 of 13
It works perfect until i add windows and doors to my walls.
Message 7 of 13
Sorry but i don't know if i worded my last post properly.
1--when i am using miter command it works perfect on walls that don't have no objects like windows and doors in them.
2--but when i add a window or a door to my wall it will not put any plates in my corners, but it will put plates into my straight connections.
I am wondering if there is a place where i can import different configuration settings?
Message 8 of 13
teodorb
Hi @Anonymous,
Please use the configuration as shown in the attached image? This is what the configuration should look like for anchor plates.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 9 of 13
teodorb
Hi @Anonymous,
Have you used the configuration as shown in the attached image?
Bogdan Teodorescu
Product Owner
Message 10 of 13
when i use cast in place it puts my anchors horizontal on the bottom of my wall , but i need them vertical in between my corners
Message 11 of 13
sorry for the confusion but now they are vertical but only where straight split walls come together but nothing in my corners.
1--but again it works good when the wall doesn't have windows or doors in them and once i put doors and windows in there it doesn't work.
Message 12 of 13
Sorry but recent post have helped me a lot.
But still haven't solved my problem.
Message 13 of 13
teodorb
Hi @Anonymous,
In order to achieve your desired behavior you could use the following work-flow:
  • Use No Selection for the connection families so that when performing the segmentation you wouldn't get any families at the desired location (see attached image);
Configuration.png.
  • Perform split to obtain your precast assemblies;
  • Manually (through dynamo) add the families (anchor plates) at the desired location;
  • Use Mounting Parts command to automatically add these families into the assembly;
  • User shop drawing to automatically generate the shop drawing for your assemblies;
For more details about using Dynamo to add mounting part see link:
http://blogs.autodesk.com/bim-and-beam/2018/01/16/adding-grout-tubes-using-dynamo
Bogdan Teodorescu
Product Owner
