Revit Structure Forum
Welcome to Autodeskā€™s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
New To Families
2 REPLIES 2
takundat1
419 Views, 2 Replies
New To Families
Hello everyone, I hope you're well. I'm very new to families and already I've stumbled upon a problem. In relation to the pictures want the Outer  Radius to be controlled by the Inner Radius such that Outer Radius = Inner Radius * 2 for the extrusions. Every time I define that formula in Types and Parameters and finally enter the values, I keep getting a message to remove some constraint and then the whole thing falls apart. I have attached the family file for further reference. Please help.
Labels (2)
2 REPLIES 2
PavelAnd
in reply to: takundat1
Hi @takundat1. Try adding dimensions inside the extrusions.
Best regards, Pavel Plotitsyn.
takundat1
Thanks very much @PavelAnd .
Forma Design Contest
Technology Administrators
