I just modeled structural stairs in place (I defined it as a floor so I can joint with the floors easier), but the stair is not cutting as per view range and I'm seeing the whole stair (for ex: in the 2nd floor plan I can see the stair from the basement) see the screen shots... any ideas how to fix this? thanks,
Solved by L.Maas. Go to Solution.
Have a look at the view range behaviour (HERE). Elements can behave differently depending on the chosen family category.
Excerpt from the link:
Elements Below the Bottom Clip Plane and Within the View Depth
Elements within the view depth are drawn using the <Beyond> line style regardless of the element's category.
Exceptions: Floors, structural floors, stairs, and ramps located outside the view range use an adjusted range that is 4 feet (about 1.22 meters) below the bottom of the primary range. Within this adjusted range, the elements are drawn using the projection line weight for the category. If they exist outside this adjusted range but within the view depth, these elements are drawn using the <Beyond> line style.
Louis
Please mention Revit version, especially when uploading Revit files.
