Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Missing Elements in Assmebly Views
2 REPLIES 2
travis.beecher
894 Views, 2 Replies
Created a WC carrier family with embedded families.  I started with a new clean family, Embedded the 3x3 angle built my frame. Then imported the 1-5/8" uni-strut for the bracing and the pipe racks.  I load this family into a project to create an assembly view for the fab shop to build.  HOWEVER when I create the assembly views the 3x3 angle disappears from my assembly views but stays in view in my plan view.  I have moved the  assembly origin point to different points in my view and they still don't show up.  Any help would be greatly appreciated.
Tags (1)
2 REPLIES 2
cbcarch
in reply to: travis.beecher
Check:
- Try setting 3D Assembly View to Fine Detail Level
- See if 3x3 angle family has any visibility parameters--i.e. Show in Plan/RCP, 3D, etc
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Forma Design Contest
