Solved by ToanDN. Go to Solution.
Solved by ERWIN-S. Go to Solution.
Solved by ennujozlagam. Go to Solution.
is something like this? thanks
use tab in your keyboard to select
I already click ref plane, i open it in floor plan so that ref plane can clickable right? it will not work if i do it in 3d then i press top?
after i follow the video this is the error. Please see the attach photo
post the file here so we can check?
here. thanks
Hello, this method not work in concrete column? Please see the attach photo
NO. you can create a customize column?
I solved it i used Generic model then cut as geometry then i hide the element Generic model and it cut the Column
good.....
I am having problems with mitering two HSS tubes using the "Steel/Miter" tool in Revit 2022.
