Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
I can't miter steel. Help
14 REPLIES 14
Message 1 of 15
ERWIN-S
700 Views, 14 Replies
Hello i can't miter the steel? Please see the attach video. Thank you
Uploaded by Niño Saromines on 2022-04-04.
14 REPLIES 14
Message 2 of 15
ennujozlagam
in reply to: ERWIN-S
is something like this? thanks
Message 3 of 15
ERWIN-S
in reply to: ennujozlagam
After isolate category i can't click my Ref Plane
Message 4 of 15
ennujozlagam
use tab in your keyboard to select
Message 5 of 15
ERWIN-S
I already click ref plane, i open it in floor plan so that ref plane can clickable right? it will not work if i do it in 3d then i press top?
after i follow the video this is the error. Please see the attach photo
Message 6 of 15
ennujozlagam
post the file here so we can check?
Message 7 of 15
ERWIN-S
Okay i will attach the. Thank you See the attach data
Message 8 of 15
ennujozlagam
here. thanks
Message 9 of 15
ERWIN-S
Hello, this method not work in concrete column? Please see the attach photo
Message 10 of 15
ennujozlagam
NO. you can create a customize column?
Message 11 of 15
ERWIN-S
I solved it i used Generic model then cut as geometry then i hide the element Generic model and it cut the Column
Message 12 of 15
ennujozlagam
good.....
Message 13 of 15
No need for custom family.  A small modification to your beam family and you can miter them easily.
Message 14 of 15
See screencast and revise Revit file.
Message 15 of 15
rprivittB3TTG
I am having problems with mitering two HSS tubes using the "Steel/Miter" tool in Revit 2022.
Forma Design Contest
