hello, I'm trying to model the reinforcement for the widening part of my I beam, but when setting constraints for my rebars, revit wont allow me to select the cover as a reference. Maybe because that cover is changing ? Thanks
please share the model inorder to check
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
Of course Ahmed, I hope you can help me with that. Thanks !
It's working with me !
I used sketch rebar and i used constrain to adujt the rebar to cover
BIM Manager
Hi, admed. Sorry for the delayed reply.
I think that you was able to set the constrain in the part of the girder without the widening, just like I was also able. The problem is setting the constrain in the widening part.
Thank you in advance.
It's because the segment plane is not parallel to the face.
The rule for a segment to constrain to a concrete face is for the segment plane to be parallel to the face OR for the actual segment (line) to be at the intersection of the segment plane and the concrete face.
