Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Generic model cutting
5 REPLIES 5
muhammad_isyraf6
224 Views, 5 Replies
I am trying to make something like a pyramid corner to fill up the gap (As shown on the right) but extending the extrusions to cut doesn't seem to work. Is there any solutions for this?
5 REPLIES 5
do you model all the element and void in same model in place ?
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
yes.
The best way i can see this working is creating a rectangle for the corner and then 2 angled void extrusion following the original shape edges so they can be used if the shape adjust to cut from this to create the pyramid shape
Jay Colcombe
Autodesk Certified Instructor
in reply to: muhammad_isyraf6
Why don't you make the main piece bigger and use void to cut off 3 sides?
Thank you very much I tried your method and it works!
Forma Design Contest
Technology Administrators
